Discuss Landlord consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Weston
I have just had a rental property tested. The electrician says my consumer unit needs replacing as it is not split load.i am only using 5ways of the current consumer unit and all cct,s are rcd protected. Is this correct?
Is that the only reason? any Testing done to substantiate his claim?
Sounds like the electrician is trying to get more work out of you!
Although any new builds or consumer unit replacements should be split load or ideally individual RCBO's, that doesn't mean to say yours needs replacing. It complied at the time it was installed and all circuits are RCD protected, which in my opinion, only warrants a code C3 (recomendation) and he shouldn't have said it "needs" replacing.
If your electrician has "failed" the installation based on the reason your consumer unit is not split load then you should find yourself another sparkie! A genuine inspector would have just given a recommendation for this issue. Obviously I can't comment on other issues on the report as you have not listed them.
By the sounds of it, you have a consumer unit with an RCD as the main switch this presents a problem/possible danger that a fault on an appliance, for example, will trip the RCD losing power to all circuits these days regulations require a single fault not to affect other parts of the installation, therefore, would warrant a code 3 improvement recommended. Regulations evolve all the time to try to make an installation safer and should a fault or faulty appliance plugged in it is disconnected as quickly and safely as possible it does not mean that just because of your installation was to a previouse addition of the regulations it is unsafe.
Are you the landlord or the tenant?
Ask for, and publish on here, the regulation numbers that it contravenes,he should have supplied you with the information in the report
Post a picture of the existing and we can go from there
In fairness there is no requirement to record the Regulation numbers against the observations in the Report.
I am the landlord. I have an electrical background but not domestic so am unsure of the current regs. The installation is as Anthonybragg describes. All other parts of the installation have passed other than the split load issue. Seems a little over the top for five cct terraced house!
I did not say there was a requirement :(
If he has a schedule of inspections he should be able to note the number of the particular regulation where a non conformity occured against the coding given for any problems
It would indicate why the inspector feels it does not comply
Can the main RCD be changed back to a main switch and then the 5 circuit breakers changed for RCBO's?
As the other's have said,it's more of a convenience issue rather than a safety issue.It's the OP's call.
Reply to Landlord consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
