Discuss LED Lighting with PIR Sensor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
We are installing LED 180W High Bay lights. Most areas have 2, there is 1 with 3 and 1 with 4 so most are 360W, 1 is 540W and 1 is 720W.
The PIR sensor we got said it could switch 2300W but after opening the box, it says max LED load is 100W. Why is this? Will the PIS be okay or will we need to go through a contactor?
probably because of LED inrush. use a 3 pole contactor, 1 pole for each run. youmay need a capacitor across the contactor coil as PIRs don't like inductive loads.
Reply to LED Lighting with PIR Sensor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
In my apartment block, our hallway has a mix of LED bulkhead lights (all same brand, 5 of them) some incandescent ones (x4). They are on a circuit...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
Hi, I live in a property built in 1911. It has had asbestos artex applied to every ceiling in the house. I am currently creating a new...
