Discuss lenghening pv cables? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Colin33
Due to a change of inverter location I need to lengthen some 4mm dc cables. These are run in plastic flexi conduit. No space for adding mc4 connectors and a junction box or dc switch would be difficult. Is it acceptable to crimp a butt joint and double heat-wrap over the joints? Each one will be staggered so separated from each other, and kept neatly within the flexi conduit. Any thoughts anyone?
should be OK. alternative is to solder then heatshrink
I only asked for volt drop , but I think you will be ok on that one !?
I think you are being presumptuous, without doing the calculations how do you know?
that extra 0.25v might make all the difference!!
:D :D :D
Reply to lenghening pv cables? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All, New to the Solar world. A question that is most likely easy, if you can tell me where I can find this in the regs or ACOP please let...
Afternoon Ive just finished PV course and have a question about DC cabling being installed through a house, from the roof to the inverter within...
  • Locked
5K
Hi, I have a dual RCD board made by Hager installed a couple of months ago. It is high integrity, which I understand to mean RCBO’s can be...
Hi everyone, I have a quick question if I may? I'm thinking of adding a second PV system to my existing rooftop PV & battery setup. As the...
