M
Mr. Anderson
Hi guys. The situation is I'm pricing a kitchen re-wire and the owner also has a new shed (6ft away from kitchen) that they would like to supply 4 single sockets to feed the white goods and a light. Price is a factor (when is it not) and the best way I can see to meet the requirements without having to go over board is to stick a 13a switched FCU in the ring to supply the 4x sockets in the shed (2.5mm radial) and then take a 5a switched FCU to hit the light requirements (1.5mm). I can't find any reason why I can't do this, reg 433.1.103 doesn't cover a second spur of a fused spur. The CU is RCD protected, the ring will be on a 32a MCB and it's a small kitchen (9 sockets total). I've considered loads on the 13a spur and there are no concerns there. ~~~Second question, why can't I hit "enter" and space out my post? Is it my lap top or a setting on the forum? Many thanks, Chris.
