Discuss Lollipop circuit or not in the UK Electrical Forum area at ElectriciansForums.net
V
varilite
Doing a kitchen revamp but not happy nice consumer unit an old GE but no rcd only main switch. There is only one ring circuit as is a flat but I know I have to put what I have done on an rcd I can either lollipop it to an rcd enclosure or install a mini consumer unit with rcd and mcb what is best? Oh yeah customer does not want to pay for a whole new cu
It's when you use a big cable to feed say an rcd then put the two 2.5's to the load side the analogy is the big cable ( probably 6mm) is the lollipop handle and the ring circuit is the lollipop
To hybrid or not to hybrid, that is the question, was this not a recent talking point with the Niceic recently in a newsletter, i vaguely remember reading about one.
@ chopper the classic is taking a cooker circuit, from the switch isolator or the outlet plate, and making a ring main off it. So as varilite has explained this takes the shape of a lollipop.
to the O/P:
well...this thread`s been going for an hour....
so maybe i missed 60 minutes....
anyway, back to my question......what work have you actually done here because from reading your first post all i saw was a load of old nonsense....
if disconnection times can be met and CCC is good etc....then theres nowt wrong with a hybrid circuit......period!!!!
I was wondering about 'lollipopping' a kitchen I'm redoing. As it stood half of the sockets / fixed appliances were on a 4mm radial (junction boxes everywhere in the loft) feeding other rooms as well, and the other half were on a 2.5 RFC, also feeding other rooms.
I have now rationalised the layout by getting rid of the RFC from the kitchen completely and leaving the 4mm radial feeding it, and a couple of unused bedroom single sockets. As it is I have fed the kitchen carrying on in 4mm, but the physical layout would lend itself to a ring. Would it have been acceptable to run two 2.5 legs of an RFC from one of the radial junction boxes to make it a lollipop, or should the 'stick' be a 6mm?
Reply to Lollipop circuit or not in the UK Electrical Forum area at ElectriciansForums.net
Hi all I am after some advice on an installation I have coming up. Its a new TP+N circuit in SWA (13m run clipped direct) for a 22kW Tesla wall...
For some Strange reason we have three Circuits running in the Kitchen i think for two OLD Cookers and a Ring Circuit for the house. Well the...
