Discuss Lollipop circuit or not in the UK Electrical Forum area at ElectriciansForums.net
V
varilite
Doing a kitchen revamp but not happy nice consumer unit an old GE but no rcd only main switch. There is only one ring circuit as is a flat but I know I have to put what I have done on an rcd I can either lollipop it to an rcd enclosure or install a mini consumer unit with rcd and mcb what is best? Oh yeah customer does not want to pay for a whole new cu
It's when you use a big cable to feed say an rcd then put the two 2.5's to the load side the analogy is the big cable ( probably 6mm) is the lollipop handle and the ring circuit is the lollipop
To hybrid or not to hybrid, that is the question, was this not a recent talking point with the Niceic recently in a newsletter, i vaguely remember reading about one.
@ chopper the classic is taking a cooker circuit, from the switch isolator or the outlet plate, and making a ring main off it. So as varilite has explained this takes the shape of a lollipop.
to the O/P:
well...this thread`s been going for an hour....
so maybe i missed 60 minutes....
anyway, back to my question......what work have you actually done here because from reading your first post all i saw was a load of old nonsense....
if disconnection times can be met and CCC is good etc....then theres nowt wrong with a hybrid circuit......period!!!!
Reply to Lollipop circuit or not in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
For some Strange reason we have three Circuits running in the Kitchen i think for two OLD Cookers and a Ring Circuit for the house. Well the...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
