Discuss Lost out to allot of work trying to follow new ever changing Regs, Part P etc in the UK Electrical Forum area at ElectriciansForums.net
sham
I have been asked on many occasions to add lights and sockets to an existing installation. When I tell the customer that I must change the MCB to an RCBO and then carry out a minor cert which all adds to the cost of the job, I know that he has called someone else who will just extent cables, connects what he has to connect and leave with money in his pocket. These Regulations and Part P has literally put me in a financial situation. Has anybody else experienced this?
Even though I should know this, could I just fit an RCD spur unit where I have to extent my cables, so my minor installation is up to regs, or am I responsible for all the circuit as I must test it anyway.
I have been asked on many occasions to add lights and sockets to an existing installation. When I tell the customer That I have to change the mcb to an RCBO and then carry out a minor cert which all adds to the cost of the job, I know that he has called someone else who will just extent cables, connects what he has to connect and leave with money in his pocket. These Regulations and Part P has literally put me in an financial situation. Has anybody else experienced this ?
Even though I should know this, could I just fit an rcd spur unit where I have to extent my cables so my minor installation is up to regs, or am I responsible for all he circuit as I have to test it anyay.
Where can I learn to speak sham? cuz it's difficult to decipher
as long as the circuit you are altering is safe for continued use, a RCD FCU is 1 solution. however, a RCBO for the whole circuit would be a greater improvement, cost differential between the 2 is minimal.
i refer my learned friend to sham's avatar.
I find if you explain it all properly to the customer the vast majority want to go with the safe and correct way,interestingly when quoting for a CU change I'll offer both dual RCD and RCBO variants and at least 8 out of 10 choose the more expensive [and IMO best] option but those that just want a cut price job with disregard for regs and safety really aren't worth working for anyway.
a minor works cert shouldnt take more than ten minutes if you are just adding a light fitting or new socket. only takes longer if you run into problems or have a fault to rectify. they come in duplicate pads and you can hand write it out, and give to customer there and then if needed.
Also from my view your example of changing the mcb to a rcbo could be considered as requiring a EIC rather than minor cert as its changing the protective characteristics of the circuit.
MCB and RCBO should have the same tripping characteristics and there’s nothing in the regs saying an EIC is required.
I had this discussion on a niceic assessment when perusing my certs and the guy couldnt give me a clear answer one way or not. So told me to eic it... i myself thought that a 6 amp mcb and seperate 30mA rcd replaced with 6amp rcbo is no different... but you know the niceic...
Sorry Gavin I dissagreewith your statement about changing from MCB tp RCBO requiring an EIC
Reply to Lost out to allot of work trying to follow new ever changing Regs, Part P etc in the UK Electrical Forum area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
