Discuss Makita 24v battery in the Electrical Tools and Products area at ElectriciansForums.net
charge it till charger says charged. run it hard till flat. charge again. assuming it's nicad. if its li-ion, don't matter, just charge and use
Even Li ion batts are limited by the manufacturer to a max number of visits to the charger. Found this out recently and thats on reason they have the chip on the battery
I always treat Ni Mh like a Ni Cad. Fully charge and remove from the charger, although the makita chargers are supposed to only trickle charge once full so you can leave them connected.
Run them until they are unable to power the tool. Not to much that you're making it labour under load, then stick em on charge
Reply to Makita 24v battery in the Electrical Tools and Products area at ElectriciansForums.net
I will be putting together 2 x 12v lead acid battery connected in series (24v basically) backup power for Internet connectivity (routers/wifi etc)...
I place the battery on the charger and it is green for about 10 seconds, then flashes red. I placed the same battery on my kobalt 18-20v...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Good afternoon, I have a 2 year old car battery (AGM 760 CCA) in a 2022 Hyundai that constantly "seems" to lose its charge. I'll check the...
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
