OP
wozz
I'd be more concerned with if the manuf specified a type of cable for the final connection, any info regarding that?
Discuss manufacturer's instructions vs common sense! in the UK Electrical Forum area at ElectriciansForums.net
i'm looking forward to the naysayers responses now...
Didn't they change the wording in the regs recently regarding manufacturers instructions or is the the next amendment a change of wording was proposed?
I suppose if you do use 4mm and the maufacturers instructions have said 6mm you may invalidate any warranty. Common sense doesn't seem to play much of a part with regards insurance companies!
Infact quite a lot of maunufacturers instructions do seem to say 6mm!
It seems as though you've based the 4mm on this one cooker, which could cause problems for the future when it gets changed. If it was a short run why didn't you just use the standard 6mm Eddie, it would't have been much of a difference in cost?
i hope you have one of these handy
He hasn't. I put it on after posting #23!
As has already been said earlier, how can a manufacturer recommend a cable size without knowing installation method, Ze, length of cable?
Since when did any type of circuit have "standard" cable for it?
Future proofing lol.
Thats like wiring a socket in 10mm2 cable beacuse one day someone may move into the house and want to connect a welder to the cable lol haha
A 6mm2 like you fella, but the OP had been told it was only 6.8kw, so he decided to stick a 4mm2 in, no issue with that under the circumstances, admittedly I would use a 6mm2, thats because I don't carry 4mm2 as standard on the Van.Come on Mike. What would you generally use for a cooker when your doing a new build?
You can wire the sockets then!I think all rings should be 10mm, no more discussions on unbalanced rings then :smiley2:
in the manufacturer's data it says that you need to install in 6mm t&e.
Reply to manufacturer's instructions vs common sense! in the UK Electrical Forum area at ElectriciansForums.net
