Discuss Measuring Inrush Current in the UK Electrical Forum area at ElectriciansForums.net
Hi - Just my opinion, but after 18mths use and possibly 1000s of pump power cycles I think its proven the service fuse is ok with the inrush current. Keep in mind the BS88 63A fuse will tolerate more than 200A for 10sec without melting and the 40A B MCB in the final circuit (say) will trip instantly. Whether the rest of the design is ok (possible max demand issue?) and there are the installation defects to chew through.
Reply to Measuring Inrush Current in the UK Electrical Forum area at ElectriciansForums.net
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
I'm trying to find a way of energy logging a home to help plan a battery installation. Ideally tracking import by hour and displaying some...
Hello! I'm struggling to find an answer to this question online. I'm new here btw - I'm a DIYer with a physics degree Currently when my fridge...
Hi guys, I have used the following image circuit to control the load. AS you see the SCRs are controlled by AC signal and The opto-triac is always...
