Discuss Metal clips in the UK Electrical Forum area at ElectriciansForums.net
Anything above a plasterboard ceiling is fine with normal plastic clips. The new reg talks about 'withstanding a premature collapse'. A plasterboard ceiling will give some degree of fire protection, thus preventing the cables falling down and blocking the exit.
Reply to Metal clips in the UK Electrical Forum area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
With current regs is 50mm enough, I know in floors they should be 50mm clear of the plasterboard, but this is a flat roof with vapour barrier and...
Deleted member 150200
Regarding emergency lighting, does a fire exit door require an emergency light above it or can you use a sticker that illuminates?
4K
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
