Discuss Metal TV Aerial Points - Earth or not to Earth?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
chrisgc
Situation:
Brushed Chrome finished metal TV aerial points (in various rooms), all fixed to metal back boxes.
Do these metal face plates all need earthing? (if so how as at back of metal faceplate there appears to be no earth screw for any earthing to be terminated into).
Note:
The aerials I believe are all connected up to an aerial amplifier which runs off powers spurred from upstairs ring off FCU).
The packaging for the metal face plates on the back reads, To be installed by qualified electrician. Must be earthed.
i would contact the manu. and ask why they don't fit earthing terminals, if they want them earthing.
Yup, for the time it would take I'd email them and point out their schoolboy error.
I emailed Eterna once about their under unit lighting pointing out that the fixing screws were 1 1/4" long and would go straight through the cupboard base. 6 months later they started coming through with 2 sizes of screws in the fixing pack. It probably didn't have anything to do with my email but I like to think it did.
Reply to Metal TV Aerial Points - Earth or not to Earth?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
I have seen a few metal back boxes that have no earth terminal lug. Do the regs state the metal back box must have an earth wire to it? The...
8K
