Discuss Meter tails in the UK Electrical Forum area at ElectriciansForums.net
Ian1981
Mentor
What's everyone's thoughts on installing meter tails >3 meters in length.
I've contacted northern power grid who said the tails where down to the electricity suppliers discretion.
Contacted the electricity supplier who didn't give a definite answer, basically do what you want!?
Buck passing at it's best then Ian
Precisely - who cares. What exactly is the point of the 3m guideline?
It is just that, a guideline, Electricians that provide tails to the CU know that.Our stance is as long as the meter is within 3m of the cut out, it's down to you lot. Connection will be given. (new installs)
This is the way I look at the topic
If I install a cable,its my responsibility to protect that cable
When it is permitted the supplier may allow me to rely on "their" fuse for (usually) a distance that has often been regarded as 3 metres max
The cut out fuse is a bonus to me the installer, not a item to be manipulated to omit my responsibility
Anything over 3 meters deserves a fuse of its own :cry::)
I had a discussion only the other day with a guy from WPD's technical team who made it very clear that their cut-out is there to protect their equipment and not the meter tails. They allow tails of up to 3M (From the cut-out not the meter) to the CU to be "additionally protected" by that fuse, but anything beyond this must have additional protection and conform to BS7671. His words not mine, although it seems pretty simple to me.
Of course, we are then in the scenario, of having two fuse in series, probably of the same rating (or of a size not to allow suitable discrimination, without reducing supply for customer), and it will be the ---- of a coin which will go first.
Never really understood this scenario, even though eminent members have explained it several time before for me :)
Of course, we are then in the scenario, of having two fuse in series, probably of the same rating (or of a size not to allow suitable discrimination, without reducing supply for customer), and it will be the **** of a coin which will go first.
There is and never has been any requirement to provide discrimination with the supply fuse
I can't see it would matter in the very rare circumstance which one popped, they are going to be off supply anyway
The above assumes a single user supply rather than a multiple sub main installation
So apart from the DNO requiring such, does it actually make any difference, i.e. prevent the Main Fuse going before the switch fuse, or are we just on about complying (BS7671 et al)?
If there were a 100 amp fuse in the cut out and we had to account for discrimination,we would end up putting a 2 sizes lower fuse (63A )to have any chance
The client could become unhappy losing a fair portion of their capacity for no apparent benefit if that was the case
Reply to Meter tails in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
We have a meter EDMI - ES30B fitted to our property. I understand from the fact sheet for the smart meter...
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
