Discuss Moved a BT master socket in the UK Electrical Forum area at ElectriciansForums.net
To those who have cut a live BT cable when moving a master, did you ring and slit the cable, then cut the wires individually, or just chop the cable with your regular wire cutters/shears, thereby causing a split second short circuit at the exchange?
Touch an old ISDN line at -96v DC and then tell me it's very low risk!! Believe me, it's not pleasant!!
Not "many" people will have an ISDN line at home and when moving a master socket treat it the same as a live cable, cut very carefully or remove the ends from the socket and tape up until you re krone.
not for long, ill have a set like jimmy carr
Reply to Moved a BT master socket in the UK Electrical Forum area at ElectriciansForums.net
Hi I’m wondering if anyone could help me I basically moved into a rental property February this year I’ve been unable to get internet I’ve had...
Has anyone had encounters with rogue landlords? I will tell my short story (and keep it as short as possible) I had a call a few weeks back from...
7K
