Discuss Multiple Oven Installation in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Been to look at some work my brotherinlaw wants doing in his new kitchen re-fit.
He is yet to supply me with all the specifications, so I can't do all the calculations as yet, but basically he wants to have an induction hob, two seperate single ovens, a steam oven, and built in microwave oven.
Initially I'm thinking that the Induction hob will be on its own circuit as its rating will probably be about 7500W, fed in 6mm to Isolator and then out to outlet point.
What would be the best way to supply the other 4 ovens ? Should I run a 6mm supply from the consumer unit to Isolator, and then loop in and out of 4 different outlet plates, or might it be better to have a local 4 way consumer unit in nearby cupboard, and have 4 x 16A mcbs supplying each appliance in 2.5mm cable ?
I appreciate you can't give exact advice without the ratings of the ovens, I just wanted to know the best way to wire up multiple ovens, as most installations I Have done before have just been one outlet point for a free standing oven, or a single oven and hob.
Thanks in advance for your help.
I would run 10mm to the hob just to be sure. Then a 6mm to the oven isolator supplying a dual outlet. The combi would have its own 2.5mm radial and i have never fitted a steam oven so cannot comment on that. All of this obviously depends on installation methods and length of run etc.
that would give you the most flexible approach as you do not yet know the exact loadings.
Hi all,
You didn't tell us that your brother-in-law was Jamie Oliver!! lol!!
Reply to Multiple Oven Installation in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
I am replacing my under counter oven with a new 3kw one, oven is on its own circuit and isolation oven switch, the cable is either 4 or 6mm coming...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
I have a double oven connection unit. Fed with 4mm cable,40 amp MCB. Hob connected to it with 4mm cable. Bought new oven,stated 16 amp but with...
