Discuss Newlec NL9-AHD Hand Drier needs repair in the Electrical Appliances Forum area at ElectriciansForums.net
Newlec NL9-AHD Hand Drier has just stopped working. Power is going to it, the thermal fuse is okay and there is a low voltage supply going to the sensing circuitry. I will do a few more tests, but if unsuccessful I would be interested to know where to have it repaired. Alternative if I could source a manual that could be useful.
nolly1953
Hi,so is there no heat,or no operation?
If the blower and heating element check out,it will be odds on that the sensing part of the job,is goosed.
If your customer has a sense of humour,hang a towel on it,and tell em' it's fixed :)
Reply to Newlec NL9-AHD Hand Drier needs repair in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Aside from every screwdriver in the universe, I wonder what the most creative mis-use of a tool you have encountered is. I'm sure this example can...
4K
I have a client on a Superdeal tariff from SSE, the Superdeal Meter has 3 sets of tails coming out of it feeding 3 DBs: (i) DB1 - the main board...
I have a 115vac line that tests with proper voltage and will power a low watt bulb but will not run a drill etc... Line from main panel to barn...
A customer has asked me to install a generator to supply her house for when they have a power cut. I have already said this is beyond my...
6K
