NICEIC Certification Scheme Niceic domestic instaler apparantly!
Discuss Niceic domestic instaler apparantly! in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Just found them. Apparently the customer had applied for a PME but it was never fitted.
Ask to see the NICEIC installers test sheets
Exactly,where is the EIC supplied by this NIC DI....and what do they show?.....If there are none then the client should formally complain to the NIC.
I dont see any evidence that this was done by an NIC DI....there's normally a sticker.
Quite frankly it looks more like a DIY attempt.
Reply to Niceic domestic instaler apparantly! in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Hi, me again :) NICEIC prices per certificate are going up, can you recommend anywhere else to buy them please?
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
Why is the word 'competent' being over used to describe what was once just 'qualified electricians' with experience? Is it to promote proving you...
Hi, I had been with Elecsa for years as a Part P installer/tester. Then they were taken over by the NICEIC. I'm embarrassed to say that I hate...
As a non-electrician (I make the tea in the forum imaginary office, I think the tea is real though) I wonder, is there a way to avoid a...
