sparkyparky
Hi guys I've got a customer that's changing a centrifugal exhaust fan from a single phase version to a 2.2kw three phase version. This is currently run through a rotary isolator into a contactor with the control run through a timer no DOL present.
My question is does something like an exhaust fan require no volts protection? If it does then I'm assuming you wouldn't be able to have a timer involved unless the DOL starter fed a Contactor which was then controlled by a timer.
How do you know what types of machine do need it (unless it is all types) excepting the obvious ones like those with exposed moving parts etc. Any help or clarification would be greatly appreciated!
cheers!
cheers!
