Discuss Off grid system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
Richard
Hi, looking for some adivce.
Looking to install a PV system, off grid. The output would solely be used for heating water. The system would be mounted at ground level, as roof mounting isn't really an option.
Were looking having a dual element cylinder fitted, one for solar, one for grid.
What I'm asking is, say the system was 3Kwp, but only producing roughtly 1.5kw, assuming the 3kw water heater was calling for heat, i'm guessing it would just take twice the time to heat up..? but that it would still function.
Thank you
We did consider that, however the panels and invertor can only me mounted some 40 odd meters away. do you think the system I proposed is feasable? thanks
Hard to say , but i would say no !
Could you not duct the pipe in some way , if you use the pre-insulated flexi pipe that is designed for solar it is very easy to manipulate and you could maybe insulate it again as well ?
Reply to Off grid system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
The unit only heats water using the programmed boost and when pressed in the 1 2 or Cont boost function. I have checked the off-peak time which...
Hi All, Main issue is as per title: inverter is stuck in Off-Grid mode. I used Self Use over the summer, which worked well, priority PV order...
5K
mididoctors
M
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
