Discuss Old conduit thread size in the UK Electrical Forum area at ElectriciansForums.net
B
Bob_T
Hi,
I don't have much electrical knowledge so am looking to get some advice
Does anyone know if old conduit loop in boxes take a different size screw than m4. I tried an m4 brass screw but this was too small - not sure if it is just damaged threads or if a different size screw used to be used.
Old boxes use a 2ba screw size which would be slightly larger than m4.
Now where can he store the other 48?
Sent from my iPhone using Tapatalk
They were the days. Domed head 2ba.
When I was starting up in the game in the early 70's my tool box always had a selection of 3/4"male -20mm female and 3/4" female-20mm male adapters for conduit they were a must have...bet there not around much nowadays...ha..ha..good old days before Brown/Black & Grey
Hi all
I carry a good few 3/4" & 1" lock rings and bushes. A good few 2BA x 1" pins too. Changing boards on metal trunking I still fit and carry 2",2 & 1/2", and 3" bushes to fit the new DB to the old metalwork.
Cheers
CW
Shoot me down if I am wrong but weren't some of the BESA box threads prior to 2BA, 3/16" BSW (Whitworth)?
Could well be. Whenever we had a problem we'd go to the Little Red Shop on Gt Hampton St Hockley Birmingham, or Whites in Summer Lane, show them a thread and they'd fetch you a greased paper bag from the back with just what you needed. sold by weight.
My old man went into the Little Red Shop in 1985 and the bloke behind the counter said "Hello Ron, you still at Sothers? He said "No, I left in 1964!"
CW.
Reply to Old conduit thread size in the UK Electrical Forum area at ElectriciansForums.net
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
I am going to need to install a small amount of galvanised steel conduit, leading down to perhaps 4 sockets and a light switch. This is in a...
4K
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
hi. would appreciate advice from any electricians. am trying to replace a 13amp [35 year old MK] wall socket but the terminal cage in all the...
