Discuss Old Crabtree RCCB replacement? in the UK Electrical Forum area at ElectriciansForums.net
Hi, does anyone know off hand if any of the newer Crabtree RCDs will fit this board?
Need to replace it & can only find the 100ma ones.
This looks like a Crabtree consumer unit that I fitted in the 80's made from the hard plastic.do you know the name of the board ?. One option if you speak with Crabtree if the bus-bar is the same to fit a newer type in. The new type could be the same footprint to fit in or they should be able to tell you what it is from your photo.
I can see some 63A 30ma on eBay, I wouldn't have thought it would be an issue to be less than 80A.
around £50 is the issue for a 2nd hand part. £10 more can buy a dual RCD BG CU>
I hate explaining to a customer that the board in place is to a perfectly acceptable standard, but because of alterations or additions they either need a replacement board or a new small unit next to it for the circuit you are installing or altering.
Yeah you always feel like they might be thinking your just trying to rip them off by carrying out unnecessary work instead you are doing the job properly to the best of your abilities and in line with current regs
Reply to Old Crabtree RCCB replacement? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Looking to refresh the MCB and RCCB (100A 30mA) units to my 20 year old Contactum P12/100N CU installed in my house. I have presently a...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hello can anyone shed some light on this fault, we have a supply into 63A 100ma rccbs that feed matte for ev chargers. The rccbs keep losing a...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
