Discuss Old Wylex Cartridge Fuse for Light AND Power = 45Amp in the UK Electrical Forum area at ElectriciansForums.net
L
lozzy73
Ok, my flat was built in about
1960, it has a very old wylex fuse box for which the fuse for the heating and
power is one switch. The lights have blown but I still have power.
In
the past when the fuse has blown the power and lighting has been lost so
therefore the fuse has not blown this time...just the lights.
Am
guessing this is a wiring issue for the lights (still on red and black)??
Has anyone come across this before?
Fuses in the box: 1 main
fuse switch, 1 for light and power, 1 for heating (not used), 1 for water heater
(econ 7).
Obviously need someone to come in and have a look at it but am I safe to use the power (no lights) until they do?
i would imagine that there is a sub- CU somewhere for the lights. have come across this on installations prior to 1950/60.
Do you think it could be a wiring issue then for the lights? Have never come across another fuse at all unless it's buried deep within the fuse box.
The weird thing is that the kitchen light (furthest away from the fuse box) blew today after I switched it on (but immediately after I switched off the fridge-freezer in the kitchen).
Just a bit worried about using anything in flat in case it causes a surge.
Impossible to give advice without more info, as said above your best option is to get a qualified sparky in.
As Nicholas said can you post a picture please?
Do you have any unidentified boxes high up on the wall? probably painted over??
Don't wish to worry you but it sounds like your flat could do with some testing to check it over too, given the age. It may be OK but better to be safe than sorry.
You say the kitchen blew - what do you mean? it went bang?
If so I am thinking that you may have a 2nd fuse board like others has said - from the OP title - 45A - you would NEVER put a 45A on lighting or a socket circuit (unless its 4mm ring - I doubt highly)
If it did go bang - stop everything and call an electrician out!
There are several on here from London so take advantage to that! Good luck!
Reply to Old Wylex Cartridge Fuse for Light AND Power = 45Amp in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi all, hoping someone might be able to help a little, we got our daughter a renault twizy, but the headlights do not work. The side lights...
