Advice please, A local shop has asked me to fit an ouside light to light up the ground outside approx 8m2 it wont be on a sensor he wants a switch putting in the shop the consumer unit is extremely old so i will hopefully talk power from loghting circuit any help with cable to use, light any help greatly appreciated not long out of college cheers
May be best in the long run to run a new supply for the outside light if possible if there is enough room in the dis board Maybe run it in a small size SWA or conduit for protection.
I agree with James if you were to put outside lights on existing lighting circuit all lights could be knocked out with a fault on your lights. At least with seperate circuit house lights would still work.
Find somewhere convenient to take power from and use a fused connection unit.. and 3 amp fuse if the loading is ok, otherwise 13amp.
You can get external IP rated FCU's to mount on the outside of a wall and run SWA from there.
Take the power through from behind it from a ring or lighting circuit. Nice and neat.
Run a Fused Switched Spur off the Ring main if you can and then run your light off the load side of the spur. Go for something like a IP rated MK spur good quality one. To seal the hole you could use a foam theres alot of things out there for that.
