Search for tools and product advice,
Discuss Panel upgrade/Tesla charger in the UK Electrical Forum area at ElectriciansForums.net
Hello I’m a non electrician home owner seeking professional advice on a quote I received for installation of a Tesla home wall charger in Madison, WI. The 200 amp electrical panel is from 1968 and has only only one available slot and the charger requires two. The quote seems high, what do you think?
Thanks for your advice!
John Lynch
1. 100A to 200A complete Service Upgrade
a. Remove and replace the electrical panel, overhead conduit, and cables.
b. Relocate to the outside of the home or Replace the existing meter socket as needed.
c. Install new 200A 40-42 space/circuits electrical Panel. 1
d. Add a Panel GFCI Outlet.
e. Ground the new system to the water line per code regulations.
f. Install 2 8' ground rods.
g. Install an inter-system grounding bridge for low voltage equipment per code.
h. Identified and re-label the electrical panel
i. Schedule utility companies
2. Pull Permit & Schedule City Inspections.
3. 2 Year No Worries Extended Warranty Dispatching fee is Included.
4. Tesla Charger a. Wall Mount EV Charging Station. Install Customer's supply Wall Mounted EV charger.
TOTAL: $5,251.56
John Lynch
TOTAL: $5,251.56
When I do an upgrade from 100 amp to 200 amp I charge $ 1000.00 for labor and the materials are usually $ 1500.00 which equals $ 2500.00 and don’t forget that you have to install a surge protection device or what we call SPD’s and it needs to be installed the first slot in the panel on top next to the main breaker. They make slim line breakers now and I’m sure you can free up some space in your existing panel and not have to up grade your panel
Reply to Panel upgrade/Tesla charger in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I've installed a Tesla Gen 3 wall charger supplied by my client. For your information, the place that I installed is in a block of flat...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
I have an interesting scenario that could use some feedback. I have 200A service in my home with a sub panel running to a detached garage...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
