Discuss PIR Issues in the UK Electrical Forum area at ElectriciansForums.net
K
kev sanderson
hi
im having an issue with a pir detector currently installed at home, it is on the top of a wall which is approx 5ft high, mounted on a bracket so it sits above the line of bricks by about 200mm,
i am getting a lot of nuisance switching, have replaced the sensor but still happening, i am wondering if it is too close to the top of the wall? not sure how this would affect it but im running out of thoughts of what the issue could be,
if this is the reason, i could overcome it by fixing a length of timber to the wall in order to move he sensor so its higher up
any thoughts are welcome,
thanks
hi
thanks
Probably all sorts of wildlife triggering the PIR
Hi - some sensors are, well, sensitive. And as Pete says, mine is set so the cat will trigger it as she slinks across the garden trying to sneak up on other little creatures :) . The sensitivity is usually adjustable on the back of the unit. To operate effectively it needs a clear view, but it doesn't need to be very high. Perhaps a bit over head height out of touch. I tend to tuck them under the eves so they've bit of protection from weather and stray light. Can I ask what type of sensor is it?
Have you tried masking the lense of the sensor? This sometimes works but sometimes it makes the sensor unreactive worth a try using a bit of tape.
As above. Some are sensitive to all sorts of things like
waving vegitation
reflected light (off a light-coloured wall eg)
heat extracts/boiler flues
all sorts
Reply to PIR Issues in the UK Electrical Forum area at ElectriciansForums.net
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
Good morning everyone. I have an issue with a Mercedes w245 B-class CDI (euro5 engine). I have an intermittent check engine light. It comes and...
Need to install a security light for a customer. He has chosen a 4000 lumens led light without a sensor. He wants the sensor to cover the majority...
The Ghost
T
Having closed down my business and gone to employed, I have a garage full of unused stock..... Looking to get rid of it as one bulk sale, am in...
Hi all, I'm pricing a job which involves re locating a fuseboard from a utility room, to garage wall backing on to utility. The installation is...
