Discuss PIR question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gshock
Hi all, first post so take it easy people :)
I've fitted low voltage lighting (MR11) to the runners up my stairs, I've fitted a Pir to switch them, the problem is that the only position that a pir an be fitted to pick up movement from the top and bottom of the stairs is on a wall at shoulder height.
This means the sensor is not working as it should due to people walking past it too closely, any ideas ?
Reply to PIR question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
I’ve been asked to price up a job which includes fitting a 100watt led flood on top of a 6m pole. Thinking of using a lamp post with a...
currently I have LED tape inside a duffuser running up the length of my stairs controlled by two standalone PIR sensors (one top, one bottom) I...
Hi All, I am rewiring my basement, which includes the stairwell that leads from the main floor kitchen down to the basement. Here is an idea of...
