Discuss power to garage in the Electricians' Talk area at ElectriciansForums.net
AJ16
I have got an underground armoured cable which comes up outside my garage wall. It's not connected yet. The question is what is the best way of doing things from here on. The garage wall is 100mm blockwork, not sure how deep the foundation strip is if any, the cable is approx 20mm dia. How should I get the cable into the garage? Should it be taken in as it is in which case the only practical way is to clip it up the wall to the eaves and in, or can it be terminated outside and then normal 2.5 T&E taken in through the wall. Of course this cable is not very bendy so that seems to limit the options both outside and inside the garage. Also if it is taken in then does it have to go to a metalclad box, or can it go to a normal small plastic consumer unit enclosure?
Reply to power to garage in the Electricians' Talk area at ElectriciansForums.net
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
