Discuss Pros...cons...preferences.. in the UK Electrical Forum area at ElectriciansForums.net
Nice low R2 readings, no messing around with earth sleeving and running separate larger CPCs. And here we are messing around with surge protection and insanely priced RCDs.
Reply to Pros...cons...preferences.. in the UK Electrical Forum area at ElectriciansForums.net
I’m a trainee electrician and would really appreciate the benefit of someone’s skill and experience on the following: Our house is a TN-C-S (100A...
6K
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
I'm planning to build a shed in the far RH corner of the rear garden. It will have a reinforced concrete base, wood structure, flat roof and be...
Short Version Is it permissible to have 2 feeds to 2 separate consumer units in a detached garage? Is it permissible to run SWA underground...
I am considering the options which may apply to the earthing arrangement for a supply to a wooden shed. The property has a TN-C-S supply from...
4K
