Discuss Rcd Switch Keeps Tripping in the Electrical Appliances Forum area at ElectriciansForums.net
B
Barney Gumble
Could somebody provide some advice to a non-electrician. My tumble dryer has for some reason started tripping the RCD switch on my fuse box when turning it on. We have had the tumble dryer for some time and used it frequently without problems and have not added any other electrical equipment to the circuit that is affected.
Any ideas what the problem is and how I resolve it?
Thanks.
How do you know its your tumble dryer?
does it trip as soon as your dryer is turned on?
Unplug your tumble dryer, plug another appliance in to the same socket outlet... turn on.. Does it still trip ???
RCD tripping is usually a process of elimination
The tumble had been running for about 60 minutes and completed its cycle and I turned it on again for a further 30 minutes but as soon as I push the ON button it tripped the RCD switch. The same happened after resetting and trying again.
Have now plugged the kettle into the same socket and switched it on with no problems so it would seem there is an issue with the tumble dryer.
i have come across this befor and it was the tumble drier wich was leaking in to electricals after 60 mins you might find that it will dry out
if not you might need to look at having it repaired
Rcd's are a pain sometimes. Call your local tester and ask 'why does my circuit trip'?
he will say call an electrician...a real one ... -;)
Reply to Rcd Switch Keeps Tripping in the Electrical Appliances Forum area at ElectriciansForums.net
I have a towel dryer on an interior wall in my bathroom, wired off the last stop in my loop of bathroom outlets. This thing has been installed...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi everyone, happy new in advance to you all. Wondering if you guys may be able to help with my faulty dryer. My dryer was not spinning anymore...
Hello, The CUR6330a keeps tripping, even when no sockets are turned on. The issue is the "sockets" switch though - it's the "sockets" switch that...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
