OP
Engineer54
oh ok yea, i didnt know if that was possible? i take it that is still ok to do yea?
Oh Dear, ....It's statements like this that make me wonder what the hell's going on back in the UK these day's!!!
Discuss RCD tripping at half the rating ? in the UK Electrical Forum area at ElectriciansForums.net
If the RCD is MEM then it will not test correctly from the rcd you have to test it downline.
AdieB
Never had a problem with them myself tbh can you explain a bit more.
Most Rcd 's are fine to test at terminals but some are designed in that the coil is connected after the live terminal thus using terminals for testing won't operate the device
Save me explaining it in full read this previous thread ...
.http://www.electriciansforums.net/i...stallations/28288-rcd-testing-no-trip-db.html
There are plenty that use remote monitoring using current transformers, ive fitted them on occasion and many brands available and yes although this thread is really about Rcd's in standard consumer units i thought it deserves a mention that other rcd devices exist that cant be tested at the terminals in this manor but regarding AdieB noting the older MEM rcd's i believe these were the only one with this issue from a domestic CU point of view.
Reply to RCD tripping at half the rating ? in the UK Electrical Forum area at ElectriciansForums.net
