Discuss Rcd vs distributors fuse in the UK Electrical Forum area at ElectriciansForums.net
Loading and diversity is part of regulations so you can't knock him for doing it by the book.
You need to do your maths again re the cooker as its wrong !
Ok we've gone of subject a bit here I appreciate the diversity situation believe me, my question is not about diversity. I simply need to know if my sparky will need to upgrade my existing consumer unit from 80a RCD to a 100A rcd, bearing I mind uk network are upgrading their fuse to 100A because we are having a granny annex fitted with a shower and a cooker, uk network made the discussion to do this as when the annex is finished we will have 2 cookers, 3 showers, 3 ring final circuits which have significant demand due to the 2 living rooms with lots of gadgetry, a garage workshop, a summer House, we also have 3 lighting circuits, a jacuzzi and all manner of ponds and fish tanks all drawing a significant current most of the time.... Please enough about diversity.
I challenge you on that, how is it wrong?
Oh but I can. Firstly, you never mentioned a socket outlet incorporated in the cooker switch!
Secondly, you never deducted the 10A before calculating 30% of the remainder. You just added it back on giving an excessively high figure!
Sorry mate but OSG doesn't say to do that, what it says 10a + 30% fl of connected appliances in excess of 10a + 5a if s/o is incorporated....
Are you absolutely positive?
Unless I've been stuck by selective blindness.... Check it out page 111
So who is "we" then? I'm guessing that you are still sparking.Here is a little cunumdrum that is probably quite simple. Uk network are coming to upgrade their fuse from a 60A to a 100A so that we can put in another mini consumer unit for a new shower and cooker... The existing consumer unit which serves the house is protected by an 80A RCD with 30mA trip, my question is, should we replace the RCD with a 100A 30mA one or is it satisfactory as the load will be split once the mini consumer unit has been installed? My understanding is the existing RCD can only handle a load of 80A and if the distributors cut out is 100A then we run the risk of burning out the RCD.
Page 110 osg household cooking appliances
1st 10amp of the rated current plus 30% of remainder plus 5% for socket outlet.
in excess of 10a
No according to English in excess means, when more than, not not including.And that, my friend, is where it says it. In excess of 10A means not including the first 10A.
Reply to Rcd vs distributors fuse in the UK Electrical Forum area at ElectriciansForums.net
