Discuss Rear lights wires came out of block in the Auto Electrician Forum area at ElectriciansForums.net
Hi all,
I have a problem with the wiring regarding the back (drivers side) light.
On taking the light cluster out to change a bulb the top of the white plastic box came off and some wires fell out.
I know its a long shot, but does anyone know which position these wires should be put back? I cant find any info on the internet.
If not then unfortunately it will have to be a trip to the garage
only way to sort that is to get a voltmeter. by switchin on tail lights/brake lights/indicators. find what wire does what. then dab 12V on each terminal see what lights up. then match wire to lights.
bear in mind that with indicators it will be yes/no... yes/no... yes/no
What does the other side look like? It will have a very similar colour code.
Yeah, then he'll have both sides with wires hanging out:eek:
to the O.P, if you lay the wires back carefully they may fall into their original place, or close to.
Presumably Chineese, Korean or a French car?
must be french... falls to bits at the first sign of the enemy.
Personally I would do as @telectrix suggests. It is not guaranteed that the opposite side will have the same colouring , and as @snowhead , if they also fall fall out you have turned a simple job into a saga.
Reply to Rear lights wires came out of block in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
