Discuss Recommendations for electric heating and hot water system required in the UK Electrical Forum area at ElectriciansForums.net
P
Pigletty
We've just bought a cottage to renovate and are looking at heating/water heating options. We have an electric supply (no mains gas and no space for oil/gas tank, similarly no space for anything like a heat pump). The current supply is max 60A.
We're thinking in-screed underfloor heating downstairs (the house has flagstones floors which will be coming up to allow insulation and DPC to be fitted, before re-laying the flags) with electric radiators of some description upstairs.
For water heating we're considering either an instantaneous boiler to supply both the shower and two sinks (one bathroom, one kitchen), or an electric shower with separate undersink heaters for the water. It won't be lived in all of the time so we won't have a bath or any real need for a tanked hot water supply.
Any thoughts/comments/criticisms/better ideas? Any recommendations for specific radiators/water heaters we should be looking at?
With all the advances in electrical heating IMO still the most cost effective would be night storage heaters as you are utilizing off peak rates and with new technology some of these units are very good.
As you are going to re-lay the flags I would recommend UFH for them. My kitchen and conservatory at home is tiled and even a small low load system makes a great difference.
It's a pity your not thinking about water storage as you could have utilized solar thermal for your water heating but they requires storage.
Thanks - I'd discounted storage heaters as I have bad memories of them from around 20 years ago. Do you have any specific recommendations of makes/models to look at?
We would like solar panels, but unfortunately it's in a conservation area and I think it's a no go.
Any thoughts on electric water heating?
Storage heaters in general are very good and have come along way in 20 years. However, before jumping in to buying them consider these thoughts. 1) inital outlay for storage heaters is high. 2) You have to have an off peak electricity meter installed to make them worth while. You will have to pay for this and you will then pay a higher standing rate charge. The electicity you use off peak will be at a lower rate but the normal rate tariff will be higher than someone not on econmy 7 or similar scheme. If you are only installing heaters upstairs I would think that the storage heaters would not be worth while. 3) storage heaters are not flexible - you have to know the night before that you want them on the next day. Electric panel heaters have come along way too have a look at Rointe, Creda and Dimplex. Just my thoughts...
Thanks - that was my thinking too - it's basically only be panel radiators in two bedrooms, so seems a lot of hassle to go with storage heaters.
Will look at the models you suggested. Have you come across The Electric Radiator Company? Their website is quite persuasive, but I've never heard of them before!
Yes their website looks very good along with their suggestions/ products. I'm not convinced though, you basically get out of an electric heater what you put in, so a 1KW output needs a 1KW supply. So with that in mind I'm not sure that their products could be more efficient than others? Maybe they hold on to the heat longer or radiate it more efectively?
for your UFH, make sure you fit the insulation tiles under the heating elements. they will make quite a difference to the efficiencey. you don't want to go warming the moles' tunnels.
I think in your circumstances the best option is to go for the electric panel rads, Rointe come highly recommended but are quite expensive. One thing you should bear in mind is that UFH is not very controllable especially over flagstones and you would need at least 50mm (probably 75mm) of Celotex type insulation and 200w of heat per sq metre so depending on the size of the house and your hot water/cooking etc load this could be too much for your 60A supply.
The other thing to consider is a wood pellet boiler/heater.
Would a log burner or similar in main living area backed up with electric heaters upstairs be an option?
That's the plan - UFH downstairs to provide basic background heat, with a log burner to give cosy heat.
My main problem is figuring out all of the possible options for electric heaters and possibilities for hot water heating. Panel radiators upstairs are looking most probable, but I can't decide on which makes to concentrate on.
Hot water is even more confusing - I guess there aren't many people who just want instantaneous hot water as I can't find any reviews from anyone who relies on it for showers as well as just sinks.
Reply to Recommendations for electric heating and hot water system required in the UK Electrical Forum area at ElectriciansForums.net
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
At Electrical2Go, we have recently broadened our product range to include water heaters. Our goal is to offer comprehensive solutions for both...
