Custom hot tub with a spa pack controller. Everything is 3 wire (red, black, white) 220V. Everything is grounded with lugs.
Goal: I have two jet pumps and one air blower controlled by the spa pack. I would like to use a relay system to prevent the air blower from turning on unless one or both of the jet pumps are on.
Thoughts: I was thinking I would use something like a CGELE Solid State Relay SSR-40AA AC to AC Input 70-250VAC to Output 24-480VAC 40A Single Phase.
Questions: How do I wire this (the more basic the better, ie red wire from jet pump one to lug number 1 on CGELE relay)? A drawing would be amazing. Do I need more than one relay with them in parallel to accomplish this? Is there an easier way to accomplish my goal?
Thank you! Kyle22
Thank you! Kyle22
