Discuss Replacement Oven & Hob on same 32 amp connection in the Electrical Appliances Forum area at ElectriciansForums.net
Hoping to get some advice as i like to understand what work will be carried out and what actually needs doing etc.
Looking at replacing the hob & oven as they are on their way out and in my research I've found out the following.
Oven & hob are both connected to an isolating switch just above the counter. This is then connected to a 32 amp fuse on the PCB.
This are the power requirements for the old oven and hob.
Old Hob
230v
6000w
6KW
Old Oven
230v
2600w
2.6kw
1. Is this safe and acceptable in the first instance? The new oven & hob are slightly less at a total of 8.3kw together?
2. If this isn't safe i guess the best option would be to get an electrician to spur off one of the plugs in the kitchen, add a socket and plug the oven into this and have the hob on it own on the 32 amp fuse?
Hi - As per George, what's been done historically should've been fine. Important now is what you want to put in their place :) .
Reply to Replacement Oven & Hob on same 32 amp connection in the Electrical Appliances Forum area at ElectriciansForums.net
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hi all, I replaced my old Electrolux oven which operated with a 13 amp plug. The new Kenwood oven I ordered says a 16 amp (Requires hardwiring to...
I have a double oven connection unit. Fed with 4mm cable,40 amp MCB. Hob connected to it with 4mm cable. Bought new oven,stated 16 amp but with...
I am replacing my under counter oven with a new 3kw one, oven is on its own circuit and isolation oven switch, the cable is either 4 or 6mm coming...
