Under Stairs Cupboard
Install 1x 10way dual RCD metal consumer unit
Install mains gas and water bonding
Testing and certification on completion+ notification to building control
1x d.socket
1x spur for boiler
1x fixed pendant light
Kitchen
4x surface mounted d.sockets- wiring to be installed inside surface mounted white plastic trunking across tiles
1x pendant light + 1gang light switch
Hallway
1x mains powered smoke detector
1x d.socket
1x pendant light+2way switching
1x BT point (router to be situated here)
Porch
2x wall lights with switch inside door- customer to supply 2x light fittings
1x outdoor suitable d.socket
Living Room
1x pendant light
7x d.socket (1 of which being USB)
2x wall lights (switch to be with pendant light switch- 2gang dimmer) -customer to supply 2x light fittings
1x CAT5 data point behind TV (cable to run back to router location)
Dining Room
2x d.sockets (to be on own ring circuit- for future new kitchen expansion)
1x pendant light (re-use existing metal fitting)
Leave coil of 6mm cable from consumer unit- under dinning room floor- for future cooker
1x mains powered heat detector
Back Garden
1x outdoor suitable d.socket (mounted on rear of house wall)
2x wall lights (one on rear, one on side+ light switch inside- customer to supply 2x light fittings
1st Floor Landing
1x mains power smoke detector
2x fire rated LED downlight in white finish+ 2way switching
Small Front Bedroom
1x pendant light
2x d.sockets
1x CAT5 data point (cable to run back to router location)
Front Bedroom
1x pendant light
4x d.sockets (2 of which being USB)
Back Bedroom
1x pendant light
2x d.sockets
Bathroom
1x IP65 rated light fitting- customer to supply 1x light fitting+ pull cord
Utilise existing new fan wiring- but relocate isolator switch to above outside of door
Loft
1x strip light +light switch high level in landing
5m run of swa from cu to a metal adaptable box on garden wall- ready for a shed supply in future
Customer moved out and removed more or less of all furniture- did have to spend 10/15mins to move a few bits in one room.
Had to lift carpets and roll them back out after- but customer to get them cut in themselves after
Customer to get her father to fill/plaster chases/ around sockets
I charged £3950
1x d.socket
1x spur for boiler
Kitchen
Hallway
1x d.socket
Porch
Living Room
1x pendant light
Dining Room
Back Garden
1st Floor Landing
Small Front Bedroom
1x pendant light
2x d.sockets
Front Bedroom
1x pendant light
Back Bedroom
1x pendant light
2x d.sockets
Bathroom
Loft
I charged £3950
