Discuss rewiring existing ceiling fan with light on a 4way & 3way(separate?) in the UK Electrical Forum area at ElectriciansForums.net
existing fan w/light;2switches(3&4way);can i put fan one 1 switch and light on the other switch?
So I want to be able to turn off the light and keep the fan going. I currently have to unscrew the light bulb in order to have the fan running without light. Can I have the light on one switch and the fan on the other switch?
currently, when either switch is put in the ON position the light comes on. if the fan's pull chain was in the OFF position then the fan stays still, if pulled to the low med or high position then of course it starts when either switch is put ON. However, the light doesn't have a pull chain for its own separate operation. If I'm willing to have the fan only operate at one speed, can i switch the pullchain to control the light, and the fan be the primary function controlled by the switches?
Sam welcome to the forum and less don’t make this to complicated to do what you want to do. To my knowledge you can go and buy new switches for your ceiling fan. What your suggestion is way to much work for a simple matter. Good luck
my take on this would be to replace the light bulb with a "smart" bulb that has a remote control system. then you could turn the light on and off with the remote as and when
Reply to rewiring existing ceiling fan with light on a 4way & 3way(separate?) in the UK Electrical Forum area at ElectriciansForums.net
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
