Discuss Ring Fuse with 3 Wires in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi again,
Old wylex 3036 fuse board,
ring 30A fuse has three wires running from it, 3 neutrals together and three earths,
has anyone got any experience of this situation and what did they find was the cause,
could be a ring and a spur, or all three are connected to the ring somewhere, just seeing what things people have found them to be just to speed up my investigation,
I am sure this is quite common in older properties, I spotted this arrangement in my old house before years ago.
Yep I will be, just hoping to get some good tips on what peeps have found when they have come across this, I suspect it was done at the time of the installation as the client has lived there from when it was last done and knows that nothing has been added to the cu since,
Was it common to spur off from the ring fuse, in the good old days
Can be done today nothing wrong with it really.
testing
Best to test it mate. I came across one with 5 phase and 5 neutrals. It was two rings and a radial on a 16 amp mcb. Surprised operating for 17 years.
My first property was a flat and the "ring" consisted of:
1 x 15A & a 2.5 cable
so unless you pulled both 15A fuses the "ring" was still live!
maybe you could do a ring test and identify the two legs of the ring main. then reconnect without the third leg and see whats not working, then maybe put that on its own fuse or make it become part of the ring or put in back where it was but mark up the board as of the findings (providing its not feeding a shower)
What you may find is a ring and a multi socket radial sharing the fuse - then what will you do.
Nothing surprises me any more wheh I remove the cover from a CU!
Ha! I have seen this before too, only with a 1.5mm "ring" supplying a dozen fluorescent grid fittings. One end in a 6A MCB, the other in a 10A.
Was done by "someone who knows electrics" who had also switched the neutral.
Reply to Ring Fuse with 3 Wires in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
HI All, I am building a new house (self build) and have my part P so am running the cabling. My reading of the regs says that any appliance of...
4K
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
