Discuss Running a 24v Spal Fan from UK Plug? in the DIY Electrical Advice area at ElectriciansForums.net
J
JackBoy
Hello all
I would like to run a Spal fan from a UK socket.
Most of these fans however are used in automotive vehicles, so there is not much info online.
What powersupply do I need to run the fan at a set speed?
Im guessing 24v / 6A will work, but thats 150Watts - I dont need it running full speed.
Could I buy a 24v powersupply with only 3A? Im wondering if the fan would run at around half the speed, which is just fine.
If I wanted to change the speed of the fan, I guess I would have to change the voltage or amperage?
Spal confirmed the fan does have the capability to be run safely at a lower speed.
a 3A supply will soon burn out. you need at least a 10A/24V PSU.
Ah really? Thanks for that heads up, If I got a 10A PSU, can I lower the amperage to lower the fan speed? or would I control the fan speed some other way?
When I spoke to SPAL direct, they said many vehicles using their fans regulate the fan speed, so it is possible to do some way.
should be OK.it's start up surge that could cause a problem. might be an idea to use 2 x 12V 7Ah alarm batteries in series (with each other to give 24A) and in parallel with the PSU to charge.
Hi telectrix,
I found a PSU with some diff options.
24v 10A
24v 15A
Should I get the 15A to help with the surge you spoke of?
Have to ask why you'd want to ?. You can buy a standard 12" 3 speed mains fan for about the same price as a PSU & have no messing about.
To alter the speed on your 24v fan, you either need a variable power supply. A fan speed control module or to be able to switch in different series resistive elements to alter the speed.
The current rating of the power supplies is the maximum current it can provide, the load will draw as much current as it needs. If the load requires 5A then putting it on a 10A power supply it will only draw 5A (after any startup inrush) and putting it on a 3A supply will just burn out the power supply.
Speed control might be possible by varying the voltage. But this will likely reduce the cooling of the motor and reduce the lifespan of the unit
From what the op says, the manufacturers have told him the fan will run quite safely at lower speeds.
According to the specs you posted, the motor can pull up to 8A.
If you want variable speed you will want a variable power supply.
As you vary the voltage the speed will vary
Most power supplies with variable voltage will be electronic regulation
And probably over load protection this is where you will run into trouble
These motors pull large currents when starting up
So your supply must be able to cope with this.
Many cheapies won't.
Reply to Running a 24v Spal Fan from UK Plug? in the DIY Electrical Advice area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Hi All, Trying to ascertain why a DC MinkaAire fan (84") will no longer change speeds, or in some cases even start itself in the lowest setting...
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
I've just had a look at an extractor fan not working. As per title it's a bungalow and there are no external walls, so it vents through the loft...
