Discuss Shaded-Pole Induction Motor in the Electrical Appliances Forum area at ElectriciansForums.net
Hey guys! First post here
I just came across a broken fan that uses this can of motor to spin the blade, I already tested everything else for faults and it is the motor that is not running.
My question is this, given the simplest type of AC motor, what are the common causes of failure?
The windings inside motors are insulated using a lacquer.
If the motors over heat, the lacquer can melt and the windings can short out.
If the motor over heats too much, the windings themselves can melt.
Common tests are IR, to check that there is no direct short between phases or line and neutral.
Continuity to check that the windings are intact.
Resistance to check for shorts between windings.
Reply to Shaded-Pole Induction Motor in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
Hello everyone, I’m based in the ROI and live in a rural location. Yesterday evening my electricity supply started to switch on and off randomly...
Lawnmower Generator AC to DC sharing common ground / neutral??? Question is general because I am trying understand fundamentals. I will give...
