Discuss Slight help with a minor works test sheet. in the UK Electrical Forum area at ElectriciansForums.net
M
Manutd4life
On a test sheet I have, it says at the bottom of one of the sheets,
Registration number ................. (The registration number is essential information)
im im not sure what a registration number this means. If I can upload a pic direct from my tablet I will, I don't have any accounts to upload an URL.
http://postimg.org/image/gb7lytfdp/
thanks
I've never done eic's or eicr's but I've seen the forms and I believe it refers to your registration body's (niceic/napit/elecsa/eca) membership number.
Thanks, Well I'm not in one, I'd have to check the regs to see if it is actually needed on the sheet or not. If not I can edit it off
In BGB page 393 the example certificate has no such requirement.
It would appear you are using a certificate originating from one of the schemes.
Probably right Geoff, I know the NICEIC do issue green certs for non members, anyone can buy them and they are a copy of their members red forms, that sheet the OP showed a link to looks like one of theirs.
If you issue the customer with a minor works then the work will not need to be notified I would think in the vast majority of cases.
The work should have already been notified as they have had an extension done, I'll give the cert to the customer, if the council accept it off them, then I can put one in for my own house that I did 6-7 years ago and I'll finally get my extension signed off too.
Ok thanks, I can edit it off the cert, I got the cert from a free download. If not I'll just put N/A in the box as already suggested
Have a look at some threads for a member called Tester Steve he has done some fantastic work putting editable pdf certs on the forum.
Reply to Slight help with a minor works test sheet. in the UK Electrical Forum area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all, Is there companies or people out there that can help source sub contract work as im not sure where to start. I know you get recruitment...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
