Discuss smoke alarms help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
banny07
hi.
I had a phone call from a customer who want me to install combined fire and smoke detectors in his 6 bedroom (three floors)house.Is he after ordenary smoke and heat alarm or something else ? what sort of cable or system need to install? thanks
If its domestic T&E will do, siting will be dictated to by the layout of the property ,guide attached
  • Guidance%20on%20Fire%20Alarms%20Systems%20in%20HMOs_tcm5-6659.pdf
I dont think combined Heat and Smoke detectors are available in domestic form, but i may be wrong have a look on the Aico website.
I fit Fire Alarm systems into HMO's (Houses of multiple occupancy) i use the Rafiki 2 wire system, the detectors can be set to various settings including combined heat and smoke. In my area the requirement for the Alarm to meet Local Authority and Fire authority requirements, is that detectors in occupied rooms be set to Rate of rise heat, and in communal areas they be set to Smoke, in unoccupied or unused areas (Loft / Cellars etc) set to combined smoke and heat.
Cheers..........Howard
Reply to smoke alarms help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
