Discuss Solar PV on a petrol station roof? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
PVdesign
Been asked to quote/design a system at a service station. One of our guys is going over for a site visit now and was just wondering if there's any restrictions regarding EX locations?
Cheers
I don't know specifically, but there will be restriction on where anything that could create a spark can be located, so ac and dc isolators, inverter etc.
same with your working method probably.
eta - you'll defo be needing to work up a full risk assessment (as you obviously will do for each job;), but lots more risks here that need mitigation measures)
Thanks for that, I've asked our guy to look at siting of isolators/inverters etc so hopefully see what he comes back with!
Of course I'll be carrying a full risk assessment and method statement as always!!!!
Cheers
cant see that as a problem! if you take the dc into the shop and put inverters there with the ac, you will need some type of containment though externally
You might want to look into hazardous areas courses as I believe this would be a requirement for working at a filling station.
I know a bloke who does work in this field but it's a bit late to phone him, I'll give him a ring tomorrow.
these two petrol stations now have panels on the main grey roofs,must be about 30 on each. petrol stations.jpg
You need the SPA Forecourt card, we have it for day to day electrical / mechanical maintenance, not for working on the pumps;
Petrol Retail / Safety Pass Alliance
Canopy and kiosk roofs fall outside of any Zone.
We used to do the HV neon lighting around the Canopy, but that's all gone LED now.
If it's for a national operator there will be a million pieces of paper to fill in and FULL PPE must be worn at all times by any contractor on site.
We do supermarkets, the rules are slightly relaxed compared.
Something you may need to consider is that most canopies have a very lightweight construction and won't support a man walking across them.
You'll need a cherry picker to get up to survey them, after you're SPA of course.
^^just saved me making a phone call... :lol:
We put one on the attached property where you pay. I seem to remember the owner contacted the H & S guy to do with the fuel and he advised him. Sure I remember something about distance from the fuel tanks had to be a certain meterage.
Reply to Solar PV on a petrol station roof? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Electrical2Go - Green2go Launches for All Your Solar, EV Charging and Renewable Needs Green2Go - for All Your Solar, EV Charging and Renewable...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
