B
Buzz-light-bulb
How's this for a means of earthing this steel conduit is acting as a tt arrangement, although brilliant ze readings, 6.41 ohms 34a. What do you all think to this.
Are you sure that's conduit?
The suppliers cables are installed within this containment, it's definitely not lead sheath
Looks like 1" conduit to me, not sure about the tt bit, does the conduit go underground? If so it'll no doubt be corroded as it's b/e, not a good idea at all!
How have you conducted your tests?
Just been thinking about this. At my Grandfathers farmhouse the electricity boards supply did enter the building as VIR’s in conduit. That was from the OH supply at the end of the building. It ran along the front of the house.
Not bad remembering that, I was seven when he died.
Reactions: 1 person
Yes the conduit goes into the ground, no way will I get a better Ze reading with a earth rod, just wondered if any1 else has come across this
Disconnected main earth and carried out EFLI test on high current
your misses will know the answer
deeper lol
Disconnect bond on that copper pipe and see what you get. lol Bet it won't be so good.
I stand by my last post no way is that conduit, just look at the tee off
Steel conduit
Buzz-light-bulb,
Lucien Nunes,
