Discuss Sub main Off a Sub main???? in the UK Electrical Forum area at ElectriciansForums.net
i have been asked to run power to a timberframe outbuilding (6mtr x 10mtr).
there is a garage cu which is a submain of the main cu, which would be easier and more practical to run the power from.
i havent actually been to the site yet, but assuming suitable CSA feed to the garage cu, can i then feed off from the garage cu to another cu in the outbuilding?
You might find it difficult to co-ordinate the ratings of MCBs if any of the new final circuits is anything more than 6A.
I don't think that it's too critical although your correct if it was any other type of installation ie commercial there would be more of a risk/inconvenience.
Hi - perhaps service split before the garage CU to avoid adding to co-ordination issues etc. I’m seeing SWA entering garage and having some half baked connection to that CU (oh so many of these). Fix that with an adjacent box and add a new SWA ongoing to the next shed, perhaps.
Reply to Sub main Off a Sub main???? in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
Now that SPD's must be fitted regardless, how does this stand from a sub-main perspective? Went to look at a job and they want a supply to a pre...
