- Reaction score
- 5,604
I was wondering about earthing and bonding today.
We take a 10mm conductor and connect within 600mm for gas/water/oil etc, but quite often pipes in a bathroom or elsewhere have a bonding clamp on them with a cable taken from lights or sockets. In the case of the lights that probably means they have a connection to earth via a 1mm conductor (lets assume they have plastic pipes along the way somewhere so are not connected to the 10mm). I cant quite see how this is acceptable given that 10mm is required for bonding?
I realise if they are not extraneous and have an RCD then 4mm supplementary bonding is not required, but this is not supplementary bonding, it is a light circuit being used to bond the pipes!!?
Any suggestions?
Any suggestions?
