An armoured 90 degrees cable is to be installed between two pieces of equipment. The equipment at either end is rated at the standard 70degrees C. The cable was tested as a 70degrees cable but another organisation has said that the cable must be tested as a 90degree cable regardless of the equipment rating. Does this sound ok..?
Cheers
Cheers
