Search the forum,
Discuss temporary feed for static caravan in the UK Electrical Forum area at ElectriciansForums.net
Doctorsparks
I have been asked by a client to install a temporary supply to a static caravan for them to live in during a rebuild, they haven't purchased the caravan yet so I'm not sure of the spec. it is going to be about 25 meters from the house. is there a standard supply for one of these?
Best bet is running some swa from the house to an outside box with commando socket RCD and MCB inside then commando plug and 4mm arctic to the static
usually a small CU, RCD and a MCB. then a hook-up lead with 16A "commando" plug and socket. obviously, their load may be more than this, so you'd need to do it differently if load was more than 16A.
Reply to temporary feed for static caravan in the UK Electrical Forum area at ElectriciansForums.net
We have started a business building garden rooms/caravans/mobile homes under the caravan act. We have only done one so far and I got an...
Hello, not sure if this is allowed but here goes, I was recently staying on a caravan park along with many others, (touring caravan not static)...
Hi there, Just about to move into a house with 2 small kids and the wiring/electrics haven't been updated in years (hard to know as it's probate)...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
I have a holiday caravan which I upgraded to a residential standard lodge. The old static had a 16 Amp supply which was OK as the oven and hob...
7K
