Discuss The need to enclose wago connectors in a box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
ARCElectrical
Hi all,
I am a BIG fan of the Wago connectors, but am I required to enclose them in a box? They seem to me, to be very well insulated in themselves....
BS 7671:2008 Ammended to 2011 Reg:521.10.1 States Non-sheathed cables for fixed wiring shall be enclosed in conduit, ducting or trunking. This requirement does not apply to a protective conductor complying with Section 543.
Non-sheathed cables are permitted if the cable trunking system provides at least the degree of protection IPXXD or IP4X.
Seems very clear now, thanks micky86.
I can only conclude that the outer sheath of a 2.5mm csa T&E is considered to be a "Cable Trunking System" providing at least IPXXD or IP4X.
wx2 steel trunking buried in mrs jones's stting room walls, can you?ell, you can't have 2
No problem.... Now if only there was a thanks button..... Haha
No, it is a sheath, hence why the Regulations refer to "non-sheathed cables". Therefore that does not apply to sheathed cables, such as twin and skin.
So . . . . .
Asking this another way, is it ok to fit a jb with the insulation showing on the outside or with the guards in the wrong place? Course not so what's the difference?
Reply to The need to enclose wago connectors in a box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
Hi All. Anyone got experience/usage of using the Quickfix Junction Box, with the Wago 221 Connectors ? https://www.quickfixjb.co.uk/...
Hi all, I’m after some advice regarding use of Wago boxes for adding a spur off a ring final. Is it okay to use a MF Wagobox with 221 Wago...
