G
gaz26
Hi all, I'm trying to sort out some heater for a block of flats, the landlord want a panel heater on every floor just to stop condensation. There is a twin socket on every floor which i'm planning on spuring off but i need some kind on thermostat spur or a heater with a therm built in so that they only come on when it gets below a certain temperature, rather than have them on a timer as i dont want them to come on in the summer. I know some panel heaters do have thermostats built in but are these for this use or are they just used as a cut out as on storage heaters.
If anyone can shed any light i'd be very gratefull or have any recommended products as someone must have come across this problem before.
you can get panel heaters, floor or wall mount, with stat and some come with timer as well.
Thermostat to control panel heaters
Australia
gaz26,
telectrix,
